Fast Fuel/Air Reader...Anyone own one?
91r/t
1:12 AM
Buffalo, NY
I am looking at something simple to plug in and tune my Charger and not leave it in the car. Looking at this....any input?
I'm not familiar with it but did you notice it says it's only compatible with Windows XP, it won't work on newer windows
Yes, I think that is only if you are trying to datalog using windows. I believe it internally datalogs and tunes without using the PC which is what I would be doing. I am only looking for a gauge while driving so I can tune as needed. Figured this would be the simplest way without hacking up the car.
I am doing exactly as above. AEM or Innovate seem to be the best deal, and both use the good wide range sensor.
If you go with it, let us know what you think
I have one and used it once. I did not use it enough to fully grasp what I was looking at. I will let you borrow it under the assumption you will cover to/from shipping costs and that I can trust you?
I would need the 02 bung and I kind of wanna own it so i can use it on multiple cars I own. I appreciate the offer though! Did it give you a live view of what the A/F ratio was while idling, running, etc...? So how old is it? Interest in selling it at all?
I recently purchased a wideband kit from PLX .. so far so good
What is involved as far as wiring goes for the gauge etc? I wanna have this be a tuning only device so I can remove it after.
That's the exact reason I bought mine, to tune both cars ... the control box is small, maybe a 3"x3" square, I zip tied it to my battery hold down and ran the power wires straight to the battery. Definitely a temp install ! The o2 wiring I ran along the left frame rail edge then behind the master cylinder brake lines, up to top of inner fender along battery cable to the main box... the gauge just plugs into the control box just like the o2 sensor. Very simple .. they also offer a Bluetooth adapter so you can link a tablet or phone to the control box so you don't have to run a gauge inside your car.... That's what I have, but am thinking of buying the actual gauge too ...
You got a link to this setup so I can check it out? :thumbsup:
NM I found the info. Basically I am seeing they do the same thing minus the ability to data log with the PLX which I could care less about. I am looking for real time cruise, idle, and WOT numbers. I like the idea of the $130 cheaper to do the same thing I am trying to do that's for sure! I would just have to buy an o2 bung and plug and that's it then.
