What is the hot spec of the cam? Those numbers suggest .012-.014" hot assuming an iron block. That seems prety tight.
Actually .010" and .012" hot. Yes, iron block, aluminum heads.
Correct...#4 cam bearing.Rocker shaft oiling for both sides is from the same cam journal, correct?
While running, the spring is going to look like Elaine trying to dance on 'Seinfeld'. It will not be stable.
Dumb ?. Keeper groove in the valve stem. Are all of them cut with a bevel on the bottom side? Doesn't look right, unless something new.
Three things that I see after a quick look at the thread.
Once I get into the 400# range, I'm for sure a 10 degree retainer and lock man.
The present 7 degree locks appear to be the cheaper stamped locks and not the good machined ones.
It does not appear to be a well designed spring for that camshaft. If the springs are set up at 1.875 installed height, they have way too much distance between your maximum lift and coil bind. While running, the spring is going to look like Elaine trying to dance on 'Seinfeld'. It will not be stable.
smoked push rods could be geometry issues. there were/are 3 different adjusters. the one for A engines and slant 6's with the interference thread, second is the one with the slot for a screw driver and jam nut, third is the one commonly used today which is longer than the other two. the longer adjuster has the ball about .100" extended vs the screw driver head adjuster (this adjuster is the one referred to in the engine manuals when threads showing are discussed). this puts the ball too far out if any threads are showing (the .100" is equal to about 2 1/2 threads showing) which is too much. add some threads showing and there can be a problem. no threads showing is what I shoot for.
too much thread showing. push rods are too short. those are the long adjusters. that's close to 4-5 threads showing using the slotted head adjusters that those rockers used to come with. when I went to edelbrock heads I couldn't find a shelf push rod to fit. IIRC I had to order push rods that were .170" longer (that's close to 4-5 threads showing) than the shelf crane push rods I was using for the same cam. the 440 source are edelbrock clones so you may have a similar situation. another factor is if those are 1.5 rockers they'll check out around 1.6. if this is the case I would check everything again. ole' joe Sherman used to say you need to up the spring pressure 6% for every step up in ratio; might check with hugh's on that.Yes they are all the same.
10 degree hardware is ordered. The 7 degree locks are from Hughes and claim to be machined...from their website:
HUG 1322
VALVE LOCK 11/32" 1-GROOVE 7° MACHINED
7º CASE HARDENED MACHINED STEEL (SET OF 16 PAIR)
What spring would you recommend? So the coil bind height should be close to max lift?
Here are a couple of pictures of my adjuster, hex head with lock nut. Distance below the rocker is .442" to ball tip and I set these up with 2-3 threads showing as I was advised...
View attachment 611866 View attachment 611867
Rocker shafts weren't put in upside down were they.
Should have been able to start up and see if they were oiling.
all the "thread showing" stuff is obsolete and probably has been for 20yrs. what I think might be ideal is the adjuster for a ball&ball push rod. as long as the oil groove in the adjuster is lined up with the oil feed hole a guy should be goldened. pair that up with some 270 degree radius ball push rods and forget about the threads showing crap.
the ball&ball adjuster has the groove. the cup and ball adjuster doesn't. I was referring to using the type of adjuster that the comp cams magnum rocker has and getting away from all the thread showing crap.There is no oil groove in the adjuster. The oil feed hole goes from the i.d., through a portion of threads, and out the adjuster side rocker arm body. The adjuster is all threaded.
Hi Threewood
some comments on your thread
some will most likely be covered by others but from the top
post 15
you can save the rockers if Crane does not warrantee
send them to Rocker arm specialists in Redding CA for a reface
I already looked into this, $504 plus shipping to rebuild the 16 rockers and hard chrome the two shafts.
56 agree ball and ball ford size pushrod and cup adjuster
also do the midlift drill and get your rockers shimmed up b 4 ordering pushrods
I'm not certain what adjusters are included with the Hughes rockers but I will definitely do the mid lift test.
Thanks!
