- 10:58 AM
- Oct 16, 2014
- Salisbury, Vermont
This is very likely a dumb question for which the answer depends on a billion other things, but here goes.
I have gotten my 440 to the point where the heads are finished and the block is as clean as I need it to be, and I want to replace cam bearings and hone the cylinders to break the glazing.
There is a little at the bottom of the bores outside of the skirts and a bit at the top but not so much that you can catch a fingernail on it. I want to get a nice crosshatch going. The clearance as measured at the top of the bores is .008. Without the glaze I expect its more like .010-012. So, this is already .030 over and the pistons are flat top TRW 2266 L. So, if I get a flex hone and clean up the bores will I be in trouble with clearance and slapping pistons? And, the other info i'm sure everyone will need to know is the intake is an M1 MOPAR, the heads are 346 ported and polished, the cam is COMP 306-4 , crank forged stock journals, rods LY , carb 750CFM Holley dual feed, distributor Mallory UniLite.
