33 IMP
- 3:00 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
I agree with Gary.Budjet is budget. I'd put it together and run it.If you don't mind some piston slap noise, I say Go For It! If it was running good before, should be better with new rings and a glaze breaker hone job, plus the other upgrades will help. I have been told, and I think a loose piston (.008) may run better in a racing application. I personally don't like the noise from a loose piston, especially on a street motor. Plus a loose piston rocking in the bore, doesn't seal the combustion pressure as well as a tighter fit does. Slap it together, and let us know how well it runs!
In the eighties, a friend and i ran a 440 duster with a cast piston engine with .008 piston/wall, about four times recommended. It was noisy enough from the .590 solid that you couldn't hear the piston slap, it had some blowby, and smoked a little at full throttle, but it went 11.70s at 117 at the old riverside raceway, and ran fine in limited street duty. We eventually bored it, put in forged pistons and picked up only a couple tenths.
If i remember those pistons, you're only about .002 over high end of spec.
