Paul_G
- 7:44 AM
- Dec 24, 2013
- Surprise, Arizona
The junk I am playing with is a 49 Plymouth with a 75 318 and a 4 speed. The car has a single point ignition system in it. I just rebuilt a thermoquad and put that in place of a Holley 600, Eddy RPM intake, B body iron exhaust manifolds through glass packs w/dual exhaust. I dont really run the thing over 4000 RPM, but it is running so well I wound it out. Then this problem. At 4000 RPM it starts to misfire, stumble and backfire through the carb. All the way to 4000 it runs really well. It pulls hard as long as it stays under 4000 rpm.
What I have done;
Timing is at 8° btdc, around 35° total w/vac adv plugged. Checking the total timing I noticed the mark is jumping around a lot. Loose timing chain?
Fuel pressure is at 7 PSI through an electric pump.
I am puzzled wether this is fuel or ignition related. How far can an old points system rev to?
What I have done;
