khryslerkid
- 2:01 AM
- Mar 10, 2010
- Hanover, Pennslyvania
This sounds so familiar with my setup for the exception that I'm running two 600's "inline".
A good carb tuner will tell you that the timing is more critical to get things right before tuning the carbs.
Your plug straps showing too much timing might make you double check again. Using the ported is what you want with a good vacuum cam. Mine didnt like manifold at all. Straps were showing too much timing so I double checked what the vacuum advance was doing when hooked up and at 2000 rpm and it was off the chart (past 60*). I had to limit the vacuum advance can to get it on the scale at 55*. That's where the low timing mark on the strap was coming from.
I'm using a Mallory dual point and a dwell meter is a must. 32* to 35*. I had to limit the points plate also because the factory setting was way too much. The springs will have a bearing on how fast your "all in" will take place too.
Now that I have my timing all worked out I went back to the carbs. I tried fattening up the rear carb because using a progressive setup, the front cylinders were way lean. Front cylinder exhaust temps were 700* compared to 600* on the other cylinders. (Useing a temp gun can show you what's going on)
I ended up going to "one to one" on the carb linkage and installing the factory rods. Using a vacuum gauge on manifold, turn each idle screw in, one at a time until you get a drop in vacuum and or rpm. Then back it out to get the highest reading. You could leave it there or turn it back in 1/4 turn. (I left mine at the highest vacuum/rpm.)
Each idle screw was responsive on both carbs and ended up in the same position when all done. Plugs are all reading good now and the engine is running great. This weekend I was getting 12 mpg.
