71 "Air Grabber" decal location
tak419
5:29 PM
Ohio
Does anyone have the measurement of the location for the "Air Grabber" decal that is on the air grabber door ? Basically wanting the distance from the edge to decal.
That help?
No. That's a Dodge. I'm looking for the location for a Plymouth. It has the words "Air Grabber" on the top of door but thanks for the effort.
Hmm I have always wondered what determined which decal was on the scoop door, lol now I know! Appreciate that!
The Charger had the Ram Charger decal that you posted and Plymouth had one different that was the teeth, but plymouth also had a white decal on the top of the door that read "air grabber".
Ok, here you go. If you're looking at the word"AIR GRABBER" from overhead: the left top corner of the "A" is 2" from the front edge of the door. The middle pinch of the rear "R" should then be 2 1/2" from the rear edge of the door. The bottom of the lettering is 5/8" from the side edge of the door.
Where were you able to find that ? Thanks you so much !
From an original scoop, passenger side:
5 cm from side edge of scoop to top of letter A
5 cm from side edge of scoop to top of letter R
5.5 cm from back edge of scoop to bottom corner of letter A
Thanks! I have it all taped off, go to install the decal and one "E" is missing an- so now need to get another set. Always something.
