67 GTX
I am trying to figure out why my temperature gauge (along with my gas gauge) in my dash cluster sometimes pin. I replaced the cluster voltage regulator.
I was wondering if (not connected to the gas gauge issue), but the water sensor in the block itself could be acting up when it gets hot?
The gauges only pin once the car is warmed up, the car is turned off, then turned back on again.
Does anyone know where I can get an original block water temperature sensor? Mine screws into the water pump housing.
