Fusible link 64 B Body...?
64SF
3:10 AM
Ocala,Florida
Can anyone tell me where the fusible link is on a 64 b body? Under the hood or under the dash? Thanks..
I can't say without looking in the FSM but, 64 may or may not use a fusible link. My 65 has a link from the starter relay to the bulkhead connector.
i don't recall seeing one on my 64 440. but i would think it would be around starter relay.
Starter relay to bulkhead connector, as Mike said.
64sf mike is right look for red wire from starter to starter relay. just looked at a picture and the wire is red with a black butt connector on it. i hope it helps
All fuse links are between bulkhead and starter relay stud. All the power coming from batt MUST go throught
I don't believe there was a fusible link on a 64. There was one on a 65. 64 and 65 have different configuration bulkhead terminals.
The original harness on my 64 did not have one. I found the the violet wire to the horn relay fried!
This clip from a 64 Chrysler SM mentions a "safety Link" though. H1 goes to the horn relay and A1 comes from the ammeter and a circuit breaker on mine.
