62-64 MAX WEDGE OIL PAN question
63 426 Maxie
9:00 AM
Valpo
All-
I am struggling to find a replacement oil pan for my 63 Belvedere 426 Max Wedge. I have been all over the web, Milodon, Jegs, Summit etc... with no luck. I bought and tried the 5-1/2" Milodon (pn 31580) but the K-member on the 63 would not allow it to fit. I see 65 and older pans all over the place but I guess the K-member was redesigned then.
Does anyone know of a place that remans the 2402307 (6qt) pan or ANY pan that will fit the 426 in the stock 63 chassis?
I have no issue with an after market (non-OEM) part as the car is not a perfect restore. The pan on it was a Milodon, 7-1/2" deep. Problem is, not enough clearance. Road rash got the better of it.
Any ideas or info would be greatly appreciated...
Try Kramer they got a lot of old style stuff. You will have to call them cause a lot of the stuff you have to ask about pricing is good. The people are great
You need one like this.
I think somebody on here has a post about lowering the sump in the milodon pan.
Rumor is that vans is thinking about repro the 63-65 bb pan
I had the same trouble for my build. Chooch may be referring to my post, under the 1962-1965 Mopars section. Look up BB/Hemi Oil Pan Project. The pan turned out pretty good, and may do another for my '65 when I get to it.
I use the Moroso 7 qt pan. No cutting anything as it fits right in with the stock K-frame and suspension. Ron
All-
I put a Milodon pan in my 64 Polara 426 wedge. All you need to do is make a small notch in the passenger side of the K member and in you go.
Just talked to Van's. He said maybe 6 months yet.
I used the Milodon pan. I think I dimpled it. And, yeah, I nubbed it on the road and took it off and pounded it back out.
Thanks all for the help. Found a stock one. Cleaned and painted. Cruisin' with confidence!
All-
Just cut a very small notch in the passenger side of K-member and your milodon will fit.
I can give you the number once I get home in March.
I used a Hemi oil pan on both my 62 Dart and my 64 Plymouth just had to trim the K frame a little even made a skid plate
FullSizeRender (1).jpg IMG_0972.JPG IMG_0973 (2).JPG IMG_1004.JPG IMG_1005.JPG
