Looking to get a cam for my 500" Stroker build this winter. I have talked to Dave at Hughes and he spec'd out a cam for me that he said would run pretty well on the street with 3.91 gears and a 4 speed. See below:
My question is has anyone dealt with Engle cams? I called and talked to Chris who is super cool and seems great to deal with. He put me at a .534 lift hydraulic flat tappet with 238 duration @ .050 which seems pretty close to the Hughes. His cam is ground on a 110 or 112 degree centerline (really whatever centerline I want) to increase my idle quality and vacuum for power brakes. Does this seem feasible? What direction would you all recommend? I am thinking the Hughes cam may give me issues with the power brakes with low vacuum but wanna hear some opinions. How does everyone feel with the same lift and duration for intake and exhaust vs the different numbers from Hughes? Chris told me Mopar cams mostly work well with single pattern lift/duration vs the duals in most cases unless your trying for every extra HP you can grab. Thoughts?
