Mark1972
Sorry for dragging up an older post, haven't been on for a while... This needs to be said.
Any of you guys installing your windshield with butyl tape are (God forbid) going to be in for a nasty surprise if you get in a serious accident. That stuff doesn't hold up and there is a reason why it isn't used anymore. Have a bad wreck and the last thing you want is a large piece of laminated glass flying around.
Have your windshields installed by professionals using urethane. That is it. Don't do anything else. A good glazier can run a damn near perfect bead of urethane that will look good and you don't have to smash the glass down into it so far that the trim doesn't fit well. It's easy to work with and, again, any good glazier can set it at the right height so your trim fits correctly.
I did auto glass for years. Cars would come in with that butyl tape crap and I could quite literally reach inside with my bare hand and push the entire windshield out - no tools required. That stuff has also, generally, been sitting on the shelf for years and it never seals worth a crap so you end up with leaks.
Urethane on the other hand has to be cut loose with a longknife razor. That's the only way your windshield will come loose. You could beat on it for hours with a hammer and chisel and you are NOT getting that windshield out except in pieces... So in an accident, you are protected. That is why they use it on modern cars, because it's the best way.
All the cars I've built have had new windshields done with urethane and they look perfect. It's too easy to do it the right way. You and your passengers deserve it.
I appreciate both sides to this, and have decided to use the urethane. I will be doing the work myself, and was wondering if you'd be able to give me a quick rundown of the steps to follow. The ledge where the window will sit has been primed and painted. The clips are in. The window has been dry fitted and seems good to install. I'm specifically curious about how much urethane to put on the ledge before laying in the glass. 1/8"? 3/16"? Once the window is in place and held to center by spacers, is more added to fill any "voids" and if so, before or after the original bead sets? I really appreciate any info.
