I have close to 1000 miles on the new comp cam and hyd lifters. oem rockers , push rods & shafts. Crane springs, closed pressure #90 , open #280. Car runs fine, pulled the covers all looks ok, Rolled the engine over checking for a loose push rod , all seem ok, shaft bolts tight.
I have one lifter that will tap for mabey 10 seconds at start up after sitting for a week.
It will not tap long enough to locate it. if I start it a hr later or the next day its fine.
Just does this if it sets for a extended time.
1st question , is it going to hurt the cam ?
2nd question, I have read comp has had some hyd lifter noise issues but mine seem fine once pumped up. Should I get another set/brand of lifters and swap them out ?
