- 1:28 AM
- Dec 4, 2009
- Pasadena, Texas
Generally, a 275-60-15 runs pretty close to 9" of tread width. I ran the same size on a 71 340 Cuda with factory front and rear sway bars and with more camber dialed into the front (ran 14's on the front but don't remember exact size) and the whole car lowered just a bit, it handled pretty good with much better than stock shocks all the way around. Also, it didn't have the poly bushings in it. Don't get me wrong, it wasn't a Viper by a long shot but for an old car still riding on original rubber bushings, it wasn't bad at all....and I'm betting on what 5.7 hemi said....28" tall tires are what you are feeling. You might experiment with more air pressure just to see if it makes a difference. If you're not running max psi, take it up there (or close) and see if it makes a difference. If it does, you found your problem. Just don't go all out until you get a feel how max psi is going to act. You don't want to spin it out and crash. You might even increase air pressure a little at a time and see if things change as more pressure will help stiffen the side walls.
