slepr1
- 6:27 AM
- Jul 19, 2014
- Stoney Creek, Ontario
I pulled my 440 and 727 out of the big Doba. The 727 was sent in for a rebuild. I'm getting the engine freshened up with new 5090 edelbrock 75cc estreet heads, a new cam & lifters and some new roller rockers.
I called Hughes up for a cam suggestion based on my build and needs. They said I need more compression with those heads (I'll be at 9.5:1) and suggested I go up to 10.5:1. (I do use 100 shot of nitrous too). They also said their 1.6 ratio rockers will work. I call up edelbrock tech and they suggested I stay with 1.5 ratio rockers because that's what the heads where tested with. Edelbrock also said 9.5:1 compression is fine with those heads as they have a few crate performance engines that have 9.5:1.
Hughes suggests their cam SEH3642BL-8...
BB HYD FLAT TAPPET CAM 236/242 -108ºLSA
LOBE LIFT .364"/.375"
Lifters:
5003 HIGH PERFORMANCE HYD. LIFTER (QUIETER)
ASSEMBLED W/ HEAVY DUTY RETAINER & QUICKER, EVEN BLEED DOWN RATES
What do you think... Rocker 1.5 or 1.6?
Add compression or stay at 9.5?
Hughes cam or Engel?
Lifters:
