Okay.. you win, I know nothing about what wears out valve guides after 25 years of wrenching aircraft. 80/87 that had almost no lead in it would let an engine go to TBO (1800 to 2000 hours) without much maintenance and when they stopped making it and everyone had to switch to 100LL (that has about 10x the lead as the 80/87) you're lucky if you can get 300 hours out of a cylinder before the exhaust valve guide to stem clearance is so bad it's like throwing a wiener down a hallway! As I also noted earlier, the other issue with 100LL is it will dry out all your rubber parts that are designed for auto fuel.
