This looks good in theory
Pops1967GTX
12:10 AM
Monroe, New York
Why? What's wrong with using the bottom plug?
We had that kind of plug on a space heater. Worked fine for years.
They give good clearance when behind a desk or furniture close to the wall. They just look odd! Does the plug have a built in swing out hanger or latching mechanism? Never seen one like that.
No, just a fixed position. It did work well next to a A/C plug.
I paint upper end houses and see those all the time. Used on floor outlets.
Just don't overload the outlet plugging in multiple fixed appliances. That is the whole purpose of the downward plug. Two of them can not be placed into the same receptacle.
I work with a lot of computer equipment and power strips/battery backups that have similar plugs.
Murphy's law clearly dictates that 70% of the time it would be better if the cord was angled the other way.
Can another plug, just like it, be plugged in below it?
I am guessing it can if the shape is octagon like the top one, or similar, it's hard to tell from the angle. I think the little wire do-hickey is actually a flip out finger pull to help pull the plug out.
The problem with this style plug is that it is made to plug into a receptacle that is installed as shown, called "happy face". If you try to use that plug in an inverted receptacle, installed as "ground up", (like I heard there was talk of changing electrical codes to), the cord would be up in the air! I personally prefer the straight in plug style, never had a problem with them!
Around here Commercial construction code is ground plug up...residential is ground plug down...:BangHead:
That explains why I have seen a few residentials with the ground up. When replacing I just put them back the way they came out to just save confusion. I have seen lots of commercial grounds down.
