Dipstick
Got my neutral safety switch out and measured it. It is dead..
I have the single wire neutral safety switch. My trans is from ‘69, shouldn’t it be the 2- or 3-pin switch to be correct?
Car is from 68 with the backlight switch on the steering column.
The change from the single-pin NSS to the 3-pin occurred around 5-15-68, so all '69 transmissions should take the 3-pin. The single pin switch will work OK in a '69 but not vice versa.
