66 Coronet outer wheel house
milsdodge
3:13 PM
Hermann MO.
Is there any one make a rear outer wheel house for a 66 hardtop. Is there something that will interchange.
No reproductions, that I am aware of. 66, 67, coronet two door hardtops, and two and four door sedans, use the same outer wheelhouse.
...and the 4 door cars usually don't rust in that common area like the HT cars do.
Isnt' the ones on the 66-67 Plymouth B body cars the same too? Been a long time since I've had both to compare.....
They may be quite similar, but they have different part numbers. I'm sure they could be modified easily if you could find a good set.
the wheel lip is quite different between Dodge and Plymouth.
would have to see them side by side
