Dodge Coronet 1969 500 convertible Trim and window
10:44 PM
28007, Madrid
Hi guys,
I'm restoring a 69 Coronet 500 convertible and I got stuck on a few things.
First I was wondering if I´m missing any part on the window mecnism on the car because the window in question goes up but it doesn't go up straight. The window has a hole on the botom right corner (photos uploded below) and I don't know if it's missing something.
Also I got the trim for the convertible top of the car but I'm missing the corners.
Parts for this rear car are imposible to find in Spain. Please, any idea on how can I fix this?
Hola Paco.
1. Convertible trim at body/top
a. The trim corners are available in the USA as reproductions. I also have those parts for sale, but mine need to be re-chromed.
b. You have the back/passenger piece of trim backwards. All the trim fits along the curves of the body.
2. Door window
a. It looks like you have all the parts.
b. You probably need to adjust the rear window guide (inside door, next to glass, has rubber inside, at back of glass).
c. You might want to replace the rubber on the front of the glass (inside the "run channel" which is the back support of the vent window) + the rubber in the rear window guide.
Thank you very much!
Sorry I didn't post this on the right place.
Recroming is not a problem. We also have to do that for some stingray parts were also doing.
How much do you charge for those parts we need?
Shamefully we don't have that rubber either(the one that goes in the run channel), we will order that as well.
Thank you again for the help and have a nice day.
Check your private messages.
