Paul_G
- 11:18 AM
- Dec 24, 2013
- Surprise, Arizona
With that being said, how much $$$ do you stroker guys have in your builds? I hate to ask, but there is always a difference between the estimated cost VS the actual cost..... just like everything else lol.
I am still in the building stage of my stroker. A little more to go before the engine is done and ready to do the small block to big block swap. I am using the Source 440-512-5060 kit. Comes out to 505CI in a .030 over 440 RB block. Doing a small block to big block swap in a 72 Charger using a 46RH overdrive trans that's already installed and working in the car.
I put together an initial estimate of $10,000 for the engine build, and $3,000 for the swap. So far, I have seen many cost increases as I buy parts compared to there prices when I estimated the build. Plan for that.
I have spent about $8500 so far collecting parts and machine shop costs. Where it stands so far is;
Short block built at the machine shop, machine work done, rotating assembly installed, cam bearings and plugs installed, short block ready for engine assembly, . Machine shop bill was $1100. I sent them the 440 Source kit which cost me $2300.
I still need to purchase the TF PP240 heads, HR cam and valve train, pulley kit which I plan to use a serpentine system, carb or EFI system, radiator, and hood modifications since the air cleaner will be above the hood after the swap.
I think my initial cost estimate of $13000 may be a little short now. Doing most of the labor myself helps. If I do go EFI that will add an additional $1500 over my estimate.
My advice is to lay it out on paper, or a spreed sheet like Excell which I used. Make sure the estimate is within your budget, and you will be much happier.
