Mike Gaines
- 7:02 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I run my timing at 37degrees total. It is "all in" on my MSD distributor at 2400 RPM.
I have my trans brake chip at 3600 RPM and before I installed my trans brake I launched off my foot brake at 3000 rpm.
So...what is the benefit of locking your timing (whether 35, 36 or 37 degrees, etc) if you launch the car at above that rpm so the timing is already at its MAX when you launch.
My motor starts easily because it it NOT at 37 degrees at startup...
Also, I do have my 5-7 plug wires separated ( #7 runs down the top of the intake manifold, around the back of the block and then to #7). I don't know if separating them is a real benefit or solves a real problem but I did it anyway because, why not ?
Your thoughts ??
Your thoughts ??
