switching to electric fuel pump question
daytona kid
9:03 PM
midsouth
When you remove the stock mechanical pump I assume you remove the shaft/pin that it operates off of also, and removing it doesn't make you loose oil psi or anything bad right?
Given it's location it likely just relies on oil being splashed on it for lubrication.
I've always removed the rods. I guess you don't "have" to, but I don't like the idea of leaving it in there.
Well, it isn't like it flops around or anything. It just slides down the hole and rests against the screw in plug.
