This will be a short thread, this is stuff goes up fast! After some members told me you can easily straighten this stuff without the rolls I tried it, no problem. I rolled it out on the floor then chalk lined and mounted the clips every 32", once installed you just tweak anything that's off and move on... easy peezy.
Here's where I dropped through from upstairs then supplied one side of the lift and will also branch off to supply the addition. One benefit I really love is the ability to bend nice offsets in the piping when you want to hit studs.
View attachment 704750 View attachment 704751
Then across the ceiling to the other side of the lift. I wanted the line ran across the ceiling so it came out perfectly in line with the other post but no joist and a metal ceiling... then I remembered these
. The other T will be to route an air drop in between the garage doors.
View attachment 704752 View attachment 704753
Across the other bay then the drop for a few outlets at the workbench then over to the lathe, that's where I stopped. I chose to mount these high so I have room for a pegboard and will put pigtail hoses on them .
