New guy here
7:23 PM
Alabama
I’m new here and I’m new to the Mopar world. I’ve been IH and GM up until now. I recently acquired a 1971 Satellite. Body is really good, no motor or transmission. I’m wanting to build a “daily”, but not a true daily. Something reliable and fun to drive, but something I can take and attempt to run time trials and autocross a little.
I have a few questions, but one at a time.
I’m planning on running a magnum 318 with a manual transmission. But the car was originally an automatic. I was thinking about an NV3500. Will this fit? And what’s a good starting point for hanging a third pedal?
Search for "gear splits" on here and FABO.
Those trans have truck style splits which will turn any rear ratio lower than 3.23 and possibly 3.55 into a granny first which will be almost unusable.
"Regular" NP833 Mopar trans with gear vendors overdrive or Passion 855 5 speed are likely the best options.
If you don't mind cutting the trans tunnel and fabricating part of the cross member, a TKO 5 or 6 can be used but I've read about some leakage issues on early models.
You can fit a 5spd out of an early dakota with no cutting but it probably won't hold up to a lot of abuse. Depends how you drive and what kind of HP the motor will put out.
what do you disagree with?
Sorry about that... but this life is about correct mistakes
:welcome: :luvplace: :xscuseless:
Y’all are awesome. I appreciate all the info. I only have one pic and that’s when I came home from getting her.
Anyone got any suggestions on hanging a third pedal in an originally automatic car?
Brewers has a kit
and is a great source of info if piecing your own
Herlitz also did the 67 Barracuda, and you can tell all three were from the same hand.
