Help spark plug reading
Very nice ! 5" at idle ? What's the engine build ? That seems extremely low, unless its got a hefty cam in it ..... you're not taking the reading from above the throttle plate are you ?
I'm taking reading from the port at the bottom of the carburetor. Not the pcv one but the other smaller one.
Yes, this is known ... however it can dump fuel at idle. ... ever have one blow out ?
No, never had one blow out. I did spend a lot of time playing with 2.5 through 12.5 valves in a couple of my cars last summer with an air/fuel meter and seeing what effects they made to the total tune.
If you have one blow out, or put one in that opens before your idle vacuum reading then you'll see how it affects the idle mixture ! You're right, they're technically not part of the idle circuit but can definitely affect it in a negative way.
Okay so the car was already set up to 18 initial and 36 full advanced. That's good isn't it?
In fact I only have 1 vacuum line hooked up right now and it goes from the back of the carb into the right side of engine block
This confuses me ... are you referring to the pcv ? I still think 5" is low ...... my 65 coronet had a .030" over 440, 11:1 compression, racer brown 520" lift cam and I was getting 6" at idle ....
I'd double check that reading then start looking for vacuum leaks .... your timing sounds ok
Is that top picture the Autolite 85 ? Looks COLD and not a lot of miles
The NGK XR4 is a hotter plug
NGK XR4 = Autolite 86
NGK XR5 = Autolite 85
Me like NGK
And that picture of the NGK s looks much better other then they are wore on the electrodes
Me like NGK
Yes top is autolite 85. I was thinking of putting in a xr4 in one cylinder to just see how it does compared to the others.
My Mopar 284-484 Cam in my 383 of old , only ran about 7-8" s of vacuum at idle
You could bee running the Mopar 292-509 Cam with the 4 speed
I drove around today with vacuum gauge and idle is around 6 but isn't smooth
I called Don and he suspects it's the 292 I believe. Whichever the bigger one is.
How many miles you have on those Autolites ?
Like I said that one picture looks Cold
One more thing , that car is Awesome
Can you post a clear picture of the Window Sticker ? Fender Tag ?
Man , some factory sweet sweet options on that car WOW
About 100 miles
Thanx !
Love The Colored Bumper Group
And of Course 4 Speed
Try The NGK s and see
Your timing is just fine. You probably need about a "35" power valve. With the engine FULLY warmed up, try to adjust the idle up/smoother adjusting the idle mixture screws & you should be very close.
Maybe it's the angle of the photo, but some of the gaps don't look to match one another.
