- 12:22 PM
- Jan 19, 2019
- Center of Massachusetts
Hey folks,
Starting my 440 build which is going to replace the 383 currently in my 1970 RR clone. This is going to be more of a road warrior vs much time at the strip. It does have 3.91 gears and in my travels I purchased a used GearVendors unit. GearVendors was really great about helping with the parts I needed even though I was not buying a complete unit. A conversion to fit my A833 was about $500 minus a new drive shaft.
The pile of parts is now complete. As it progress's I'll be adding pictures. It's my second Mopar big block build. The previous is a stroked 383/438 in my vintage drag boat. I had good results using a 440 source kit and their cylinder heads. Comp XS282S and a Weiand tunnel ram.
The goal is 475-500 hp but most of all, a broad/flat torque curve along with being able to run on 91 octane pump gas.
Specs::
1968 440 block and main caps. (blueprinted and cut to .000 deck which gave me 9.97 to 1 and a .040 quench)
ARP main studs, head bolts and a complete engine fastener kit.
Eagle crank & rods (3.75 stroke) ARP 2000 bolts
Icon pistons with 12 cc relief/dish (4.350)
Hughes STL3842-8 cam ( Anyone who is running this cam feel free to comment)
Melling HV oil pump
Milodon 7 qt road race oil pan
To answer the question of why a 440 and not a stroked 383 or stroked 440 is simple.
1) I Got an incredible deal on the crank and rods. NIB.
2) It's not a numbers matching car, and a 440 has a little more resale value along with better choices in pistons.
But mostly is was the deal I found on the crank and rods. To be honest, that triggered the 440 upgrade. LOL
I'm want to give a shout out to the shop I use.
R & L Engines in Dover New Hampshire
http://www.rlengines.com/
Have not purchased the heads yet. The plan is to use the 440-Source heads. There are better heads for all out performance however they flow enough air to build the power I want in a street car.
And I'm on the fence about which rockers. Several good choices and I'm open to suggestions. The boat motor has Comp Cams Magnum rockers.
And have not decided on an intake at this time. The car has a fully functional Air Grabber so height is a deciding factor. Just been too busy to measure clearance, maybe today or tomorrow. A 6-pack is a possibility depending on how much my wallets hurts next month. But that is something I can switch to at anytime.
I'm working on the short block this right now and have to put the steering back together. It's winter in New England. No sense rushing.
The shop is heated, I'm retired and my Service K-9 loves to help out in the shop. He's from Europe so I have to tell him everything in metric.....
Specs::
Melling HV oil pump
