Steering coupler help
OH71RRunner
1:20 AM
Fulton, Ohio
Apparently, I'm missing the metal bracket thing on my steering coupler. The rubber boot keeps sliding up the shaft. Is this going to be an issue? Can I just wrap some electrical tape to keep it from sliding up?
Here's some pictures of what I'm talking about
Zip-tie might work better than tape until you can get it fixed properly.
You could use one of these before and after you get the rebuild kit. Just Google "Mopar Steering Coupler Clip"
Do I need to rebuild or replace the coupler or just put the clip on and all's good?
Ma sez "if you disturb, put on this here clamp!" :thumbsup:
If you’re that close and you don’t know when or if at all it’s been rebuilt, I’d do it! Kits are not that expensive and I would definitely get a clip as pictured above for the final piece. I just did this last winter and wasn’t bad at all. I will say, that retaining clip can be a real pain to get on! It’s tight!
I have the cover/retainer if you want one. I'll bet the inner parts are OK to reuse if cleaned and greased. Shipping only for used cover from MI.
Those wire clamps can be a bitch to install.
First of all, thanks for the replies and help. After some rather choice words, I got the steering column out and coupler off. Got the internals and case soaking. That grease in there was almost hard.
Is this pin supposed to come out?
I didn't want to beat on it, but it doesn't seem like it wants to come out. I looked in the FSM and I didn't see anything about it coming out. It's possible I overlooked it.
Yes, that pin comes out and you'll want to reuse it as the rebuild kit pins are ****!
Use a press, or get a deep socket that fits over the pin.. put the socket on the floor, pin in socket and solid blow with a BFH !
not wanting to hijack the thread but where is a good place to get the rebuild kit for 62-64?
Is this pin supposed to come out? View attachment 715574
I wouldn't take the pin out if it's in good shape. The seal and metal cover will slip over it. The one I had, the pin was really in there tight and I was afraid to screw it up trying to remove it.
The shoes only go in one direction. If you didn't take note of their orientation let me know and I can post pics.
I actually acquired one on ebay from seller Hemi Eddie. He had the right one with the black seal instead of the red one that you normally see. Other than him I would try Joe Suchy.
