Head Gasket Question
tnfastback
10:51 PM
East Tennessee
Just picked up my stuff from machine shop for my 512 Stroker/Six Barrel build. I purchased kit and stealth heads from 440 Source. My question is the kit + heads calculates to 10:5 compression using a .039 compressed head gasket. Using Cometic gaskets and thinking of going .051 thickness. Does anyone see this as a problem?? Also is 4.380 correct for .030 bore??
The thicker head gasket will just lower your "static" compression ratio (you can use online calculators to see how much).
On the bore, no. Stock 440 bore = 4.320", so it sounds like your block is .060" oversized, not .030" oversize bore.
Stealth heads I assume they're aluminum? ((I'm not a wedge guy) If aluminum why go thicker?
The Std. bore on a 440 is 4.320". So +.030 is 4.350 . What is the deck height on the machined block?
Yes they are aluminum. I was thinking 10:5 is flirting with the current crappy gas quality, although 93 is available around here. Car is cruiser only and only ended up going 512 due to worn out stock internals.
Depends on what block you start with. You can build a 512 with a 400 block bored .035 over, or a 440 block bored .060 over with 4.25 stroke crank. That comes to 4.380. So if you are building with a 440 block, .060 OS pistons will work. Need to know what pistons you have yo calculate C Ratio. Are they the flat top with a dish ?
Standard deck height was decked enough to clean surface. The put some specs on paperwork, so I will have to look.
The calculator is pretty accurate. Plug in your numbers and see what you have. .010 of space works out to about .2 on the static CR. Ideal quench on aluminum heads is .040-.050 with .040 being the better end of the tolerance.
How long the valves stay open have a big effect on cylinder pressure and chances of pre-ignition.
https://uempistons.com/p-27-compression-ratio-calculator.html
You will want to have about .035 quench if you are running 10.5 C Ratio. Helps the mixture burn better, and Resists pinging. So choose a gasket that will give you .035 head to piston clearance
I think OP was asking if the 4.380 gasket is good for a .030-over block...yes. You don't want it hanging over anywhere, the often used tried-and-true Felpro 8519 carries a 4.4" diameter if I remember correctly...
What camshaft are you using? 10.5 will run with aluminum heads if you are using a cam that's not stock duration. 240@.050" or bigger?
I ran 13 to 1 C Ratio on a 451 stroker, 242 int duration @ .050. At 5400 feet you can do that. Also had to run 50/50 race fuel with premium, (98 octane) , mixture on the rich side, ran the motor cool, (it was more likely to ping when hot) , 38 degrees total advance, 2500 RPM torque converter with low gears in the rear. Don't want to load the motor much at lower RPMs.
The light just went on!!!! I think 4.380 should clear the chamber and bore. The Felpro 1009 which I've used is 4.410. Thanks Beanhead!
