EngineerDoug
Oh boy...I tried to install a new windshield in my '68 Coronet today. Did not go well, though I did not damage the glass. Here's what I tried, and maybe somebody can give me some pointers on how I went wrong.
I started by running a bead of the butyl sealer along the entire pinchweld, which has been repaired and painted so it's pristine. I then set the gasket over the pinchweld and seated it along the cowl. I lubed the new windshield with Windex and seated it in the cowl channel of the gasket. I tried to ease the glass into the gasket, working my way up each side using plastic pry tools.
This method stalled because the top of the windshield was held out by the entire gasket segment along the roof. There just seemed to be no way to coax the gasket channel over the glass so it would stay there. The gasket kept coming off the pinchweld.
For those of you have done this job, did you install the gasket onto the car first, as I did? Or did you put the gasket onto the windshield first? Would I have been better advised to do it this way and "rope in" the gasket + windshield onto the pinchweld?
Your advice is welcome, as I am prepared to let a pro install this thing.
Thanks.
Thanks.
