Window regulator question?
Terry Kitzman
12:05 AM
S.E. Iowa
Are the front window regulators the same on a 1966 Charger and a 1966 Coronet?
Don't know but don't see why they would be different....
Yes, they are different as stated above. The door panel is padded on 66/67 Chargers therefore if you use a Coronet regulator which I understand will bolt right in, you will not be able to put the window crank handle on it.
Does anyone know if anybody reproduces 66-67 charger window regulators?
Classic Industries Product numbers MM1088 and MM1089 but are only for 1967 Chargers (2 dr Bs)
Terry,
Your in box is full, I may have an original driver side regulator if you still need it
