Frame connectors how did you do it
that looks great. you have a great car your build is show and go. thanks for your help
All of you can’t believe the difference with connectors installed- night&day. Have to say that I have no experience with bolt-ins.
Oldbee, thanks all positive responses again thanks goes out to all of you for sharing. Going to do grams and relocation kit at the same time. Will send pics when I get started
I have done several cars with 2"x3" retangular tubing thru the floors. Did one of my Challengers all hiden in the rocker panels (the Hemi orange car). My current Challenger is all round tube tieing in with the cage bars & removable driveshaft loop is tied into the frame connectors.
This is for everyone who added connectors. When the connectors were added, was the car stripped, or complete? If stripped was it braced on the inside? My car at this point is stripped. Before I put it on a rotisserie, should I reinstall doors, fenders, etc and cross brace the interior before I add connectors? Any addition information would be appreciated. Thanks
Those fit better than my US CarTools. Very nice work.
Thanks. I took cardboard and traced the floor outline, then used the cardboard as a template to cut the steel. There are sections taller than the 3x3. Those were made by butt welding above the boxed 3x3 with flat steel. I like how some guys slit through the floor but for me, I cut the 3x3 down to fit to the floor and then rewelded the tops with metal to close it up and retain strength. This was before I got the 2 post lift. It sure would have been easier to do today!
I had to extensively trim the US CarTools to get them to fit perfectly. Nothing major, but it took some time with the Dremel.
Complete car. Doors closed. No interior intrusions. Carpet left in and no fire.
I made a set for my 64 Savoy out of a length of 2x4 tube. Coped out a pattern from a piece of FRP board and cut em out and welded em in. Be sure your car is setting level before welding em in. Piece of cake.
Not just level, but on all four wheels if the car has not been gutted.
its gutted the only thing left in it is the rear diff.
