LemonWedge
Nice units . I like these or the plate system over a throttle stop as you still use full throttle so you get correct airflow through boosters etc .
Tex
I’m not so sure about this Tex.... no matter what it is thats restricting the flow, throttle blade or this device, it’s the velocity through the Venturi booster that draws fuel. It shouldn’t matter what restricts said velocity. No matter what position the throttle blade is in, the same amount of air velocity should draw the same amount of fuel.
