tool A-8394
Are you replacing it? Let us know what brand you use and how it works out if you are.
I'd like to see a pic or two once you get everything installed. A few of us were having clearance issues useing some of the aftermarket idler arms and tie rods.Yes I am replacing it. I got the Super front end rebuild kit from PST.
I installed a Moog K779 last spring and it fit perfect.
Can you tell me why you guys buy PST stuff? All I hear is how it doesn’t fit and many other problems.
One was the tie rod end being too close to the torsion bar when it passed by it. The tie rod ends were bigger in design.I’ll post pics once I’ve got them installed. Where are the clearance issues happening?
The idler arm had a slight difference in shape and it made the center link closer to the pan. You probably won't have that problem. Looks like you have the small block engine (Poly).
Side by side they look the same however once I put it one it is hitting the exhaust
View attachment 727138 View attachment 727139
Hit the stud firmly and squarely with a hammer, it will pop out. You,already have the nut in place correctly.
