alcohol paul
New Member
How much could one expect to pay to get a 426 hemi rebuilt.? Complete job, removed and installed, turn key.
Thanks, Paul
Thanks, Paul
It is Larry Shepard. Look him up at www.HEMISONLY.comPaul you’re in luck. Look up Larry Shephard(?),Akron,Oh on S.Main St. He should be able to help & not too far away.
So, what did it dyno at? Got a hemi out at the moment, somewhat similar...maybe.LOL. 430" 11-1 comp,roller cam, weiand tunnel ram, 750 dp holleys, stock heads and big oil system. Oh, and direct port system under the manifold with a spray bar system in the plenum. But I wont be using that for a while. If ya dont mind sharing I will keep the numbers to myself...lol. Good looking piece you got there!I have somewhere around 17.5G's into mine. Years of gathering new and used parts. Mine is obviously way above stock. If you have everything already and was a running Hemi before, I would say probably 5-10G's for the rebuild depending what it needs.
