It used to be a joke around the airports back in the 70's that Boeing was operating a giant fuselage machine (like a sausage machine) and they simply cut off the required length for either 707, 727 or 737. The 727 did share much fuselage and cockpit with the 707, and while initial plans were smaller, to save costs the 737 wound up with a lot of the same fuselage structure. Same inner and outer cross section diameters and seating. Incidentally, the 757 was also derived from the 727. Original designs for it even included the T tail, later dropped. But the fuselage cross sections still show the heritage.No, other than being jet powered single-aisle aircraft, built by Boeing, and have the number "7" in their names, that's all they have in common.
707 - 4-engines under the wings, up to 215 pax, first flown in 1954. The only 707s flying are purpose-built AWACS and USN E-6 aircraft, plus JSTARS and a handful of specialty aircraft. Over 1,000 airliners and 800 military derivatives built.
727 - 3-engines (2 mounted aft, one on the tail), up to 120 pax, first flown in 1962. Fewer than 45 remain flying worldwide of 1,800+ built.
737 - 2-engines under the wings, anywhere from 60 to 190 pax, first flown in 1967 (Max series in 2013). Civilian and military derivatives total over 10,000 flying, with over 1,400 airborne at any given time
There is no "derivation" at all between the three. All are very different aircraft.
Sell Tesla.Boeing stock is down. Buy.
Really? I heard it was dropping. When do you think it will go back up? 1 month? 6 months? ThanksBoeing stock is down. Buy.
Usually an info page stored on the back of the seat in front of you. Shows the emergency exits, aircraft info etc. Also the flight attendants should know. Dont think I have been on a Max 8, but it was mentioned as coming soon, to Southwest.Just flew Southwest last week. 737. Beautiful aircraft. How to tell it’s a Max B?
I know whats wrong. It's the nut behind the wheel! Replace that nut, then the car will work fine.A lot of Hellcats are crashing. There must be something wrong with them.
I guess there's always that chance, but not likely. Why would they choose a new airplane that only crashes on take off? Besides that, security is pretty tight. Not sure how it is over there, though. Hmmmm.....So is there any chance the crashes are terror related?
Where is the outrage over this?It used to be a joke around the airports back in the 70's that Boeing was operating a giant fuselage machine (like a sausage machine) and they simply cut off the required length for either 707, 727 or 737. The 727 did share much fuselage and cockpit with the 707, and while initial plans were smaller, to save costs the 737 wound up with a lot of the same fuselage structure. Same inner and outer cross section diameters and seating. Incidentally, the 757 was also derived from the 727. Original designs for it even included the T tail, later dropped. But the fuselage cross sections still show the heritage.
Oh no! You didn't like what I said so you blocked me! It is the end of my world!SlapStick is now blocked. Done with his bullshit. He did nothing to prove his supposed point. "Look it up" is not the way you prove something. He must've sucked *** in debate.
Not a production vehicle.erm....not to ruin it for you,
but the first original minivan was actually either an Amc or a dodge concept that was shown back in the late 70-s....almost positive it was an amc.
pretty sure if i google it i could pull a pic too.
even better a full story link.
https://www.thetruthaboutcars.com/2017/10/rare-rides-a-one-off-amc-concept/
You must have hung around different pilots than I did.Been around these damn things for nearly 40 years and have never heard that before. Ever.
There are so many variables on this, it's hard for one to make a honest statement about this. The Black Boxes won't lie about what happened.Saw two articles today where there were reports of a vibration and shuddering on the plane, plus ground eyewitnesses who saw "smoke and debris coming from the plane" on its way down. Sounds more like a bomb, explosion causing flight control problems, or similar situation. Planes have crashed because of lithium batteries in the cargo hold catching fire and exploding. Everyone is quick to blame Boeing or the airline, when the cause may well be something neither could foretell.
You guys were the know it alls. You all said I was wrong. If you were so correct why didn't you prove me wrong?
That's right...you couldn't. You could have done as I suggested...look it up. Either you didn't and remained uninformed or you did and saw you were wrong and couldn't admit it.
But if you are so adamant you are correct you can post links to prove the other guy wrong.
Apology accepted.
...cr8crshr/Bill
