using lye to clean a gas tank
greycharger
11:38 PM
unkown
Cleaning a gas tank and am wondering what others have done. Thinner didn't work. I bought a 50 pound bag of lye today and plan to use it. Has anyone used it? It's what radiator shops used. I'm wondering how to determine a mix ratio and strength. Obviously, it is very dangerous stuff.
I used the POR15 kit. The cleaner was called "Marine Clean", if I remember correctly. Worked well.
I used a product named "Spartan Cleaner" and it worked well. I mixed and poured it in tank, sealed and shook it up several times in 24 hours, and pressure washed it out before coating. A mouse had died in the tank also.
The safety data sheet for Marine Clean says it is Potasium Hydroxide, a type of Lye.
Marine Clean is by weight: 90 % distilled water, 4% Potasium Hydroxide, 2% surfactant (water wetter) and 4% ethoxylated undecyl alcohol.
I'll call the chemical store to find out about the ethoxylated undecyl alcohol and maybe make my own Marine Clean.
I paid $1 per pound for the Lye.
So you're not working on a Charger?
Be extra careful with the lye. Outside with a respirator. Watch mixing different chemicals.
And when you're done mix it with some water and soak some whitefish in there.....mmmm lutefisk.
Working on a Chrysler... and now I think the black guck is not fuel residue, but a sealer... and factory at that! It's soaking in lye, but I don't think lye is going to cut it. Now I'm thinking acetone or alcohol.
Inside my old tank. Looks like varnish and probably lead deposits. Bought a new one. Seam was leaking too.
