What rear end is this?
Moparfiend
1:19 AM
HOT
I count 9 bolts but it does not match any of the rear ends identified in the chart. My goal is to add a sure grip if possible but I need to identify it first.
Thanks MF
272EFBEC-C954-46BE-A40D-D1644C9EB998.jpeg 5A7FE743-AA94-40D7-89BC-000AD60713CA.jpeg 19D49DF1-C407-41A3-A136-9D0FF4FF8EBE.png
Ok is this a 71/4? 9bolts....??? Looks like it darn
if it came in your 70 satellite 318 it was a 8 1/4
they never put a 71/4 in a b body
that was a a body rear that would need some kind of mods to fit a b body.
Yes its the original rear end from my 70 Sat but its round not oval??
that stupid pic is not a exact representation
its a 8 1/4
I have one from a 71 that will hit scrap one day as nobody wants them
and I used to have one from a 70 318 car
I some how sold that one
its a 8 1/4
Any idea if I can convert to a sure grip? Worth it?
9 bolts for the 7 1/4, 8 1/4 had 10.
yes you can add a sure grip
might take a bit of searching for the parts
worth it?
depends what are your plans?
if you are looking to go faster,more hp ,most people toss them and upgrade to a 83/4
that will hold up longer.
never heard of one in a b before???
still looks like the 8 I have to me
now I have questions
are the perches moved at all?
any offset hangers??
does the car have a fender tag???
the codes will tell you exactly what it came with
No telling how it got there....I've found stranger stuff in these 50 year cars. I enlarged the pic and the axle tube kinda looks like it's been welded to the center section....? Also, it's been so long since seeing a 7 1/4 that I'm not sure if I'd be able to identify one lol
Not true. I have a 7 1/4 here from a factory 225 '66 Coronet. There's a 7 1/4 from a '71 318 Barracuda in the woods next door (yeah, E body I know). They were used w 318 A bodies, likely w 318 B bodies too. Definitely not common though. Your axle in the pic is a 7 1/4.
https://play.google.com/store/books...HP5SjbHzaNCy1Av7mGRoCrDoQAvD_BwE&gclsrc=aw.ds
My 66 Belvedere came with one too.....225 auto. Was thinking that by 70, they weren't using them anymore? Probably /6 cars. No use using anything bigger for one.
I'm talking about 68-70 b's
I should be more specific
maybe it could be a transplant from a earlier year might explain some questions ?
as I owned a 70 belvedere 318 auto with a 81/4 rear
bone stock
does the car have any of these codes on the tag?
D51 69-71 2.76:1 Rear Axle Ratio 8 1/4
D53 69-71 3.23:1 Rear Axle Ratio 8 3/4
D55 69-71 2.45:1 Rear Axle Ratio 8 1/4
D56 69-71 3.54:1 Rear Axle Ratio Dana
D57 69-71 3.91:1 Rear Axle Ratio 8 3/4
D58 69-71 4.10:1 Rear Axle Ratio Dana
D69 69-71 Special Order Rear Axle
D91 69-71 Sure Grip Axle
I didn’t see anything showing axle type the metal tag that can be seen shoes a 271 ratio however.
