Wire Glue?
Ron H
8:18 AM
WI
Has anybody used wire glue? This is supposed to be a heatless alternative to soldering. I've done some sifting on wire glue and for the most part, the reviews are positive. The gas and temp gauges are out and finally discovered a broken wire trace on the circuit board. It's the sort a situation where heat soldering could create other ills so pondering on this approach before I end up heat soldering or buying a new board.
Thanks.
ford use to sell a bottle with brush to repair rear window defrosters this was a conductive paint when ele is applied will cure and on a circuit board cover with ele tape as you don't have something short out.
I'm with Vance on this one. You can buy a rear window defogger repair kit at most parts stores & the tiny little bottle of copper-filled brush-on coating is conductive. I've used it and it works just fine. That should fix your problem.
yay that
's the stuff
Thanks guys. The wire glue stuff is filled with carbon fibers I gather and takes a hard set after several hours as I've read up on this stuff. The de-fog kit you mention...does that take an adhesive set I suppose? I inserted a pic of my damaged circuit board FYI. The entire discolored section of the trace wire uprooted itself from the board and part of the wire split so have a gap there. I imagine will need to super glue all that unless the product you mention takes care of that.
using the defroster glue with a few strands of cut copper wire should do the trick. no carbon fiber i think it is zink with a glue compound.
I had one like that and soldered it probably 20 years ago and it's still good, i think i used something like 18 ga wire, cleaned and tinned the strip and wire before soldering
Ok, I'm going to nix the wire glue I have and found a Permatex rear defroster kit online (after stopping at NAPA and Auto Zone looking for this stuff today). Another kit that looked good can't ship before May 22nd...chit I hope to get my car back in operation quick as summers in my locale last a few weeks...again I appreciate your advice folks!
You've got the right stuff. It's an acrylic 1-part air dry with copper......literally, nail polish with a bunch of copper in it instead of red/pink color. The copper conducts electricity. The stuff works. I highly recommend that if you have any cracks in the board itself, to lay maybe a single layer (2 max) fiberglass patch on the back side of the gauge cluster (the side with no electrical circuit) where needed. Then you just clean/dry the damaged section & bridge that gap with the copper "nail polish"
