4mulas
- 6:07 AM
- Mar 16, 2017
- Just North of Great Falls
So I picked up a used 383 that I was told needed a rebuild the other day only because I needed the bellhousing that was attached to it and he didn’t want to separate it. This was all good with me as the engine also had several other parts in it which I needed any like motor mounts, hp manifolds, Holley street dominator, engine tin, etc.....
When I got it home and upon further inspection it’s a 69 HP motor. So I yanked a head to have a look and it has has had a rebuild once and is currently .020 over with ZERO ridge in the cylinders and no scoring at first inspection. Well this is intriguing, I think I can use this motor as I’m looking for one to put in my Belvedere. Now that I’m contemplating using this mill I decided have a closer look at the iron heads. Turns out they are the early 516 closed chamber ones. I know that lots of people don’t like them because of small exhaust valves etc so I turned over to have a look and viola! Someone punched out the exhaust valves to the larger 1.74 which from what I read was a must if you want to use these heads. A further look showed rebuilder ID stamped into the ends of the heads with a little rebuilder button attached to them too. I’m going to take them apart to have a closer look but at an initial glance they look good.
Now the question and intention is: I intend now on finishing the disassembly and if things look okay I will re-ring the Motor and will re-use the same heads too. Having not done a motor for a LONG time I really need recommendations on a descent good quality but not killer expensive complete gasket set. The pistons in the motor are flat top and are just ever so slightly below zero deck, I haven’t measure yet but will.
If someone knows these motors and can tell me roughly what thickness head gasket to look for with these heads I would also really appreciate that!
