4 speed Conversion
4:25 PM
Penticton, BC Canada
I am converting a 68 Coronet to 4 speed, I have most of the parts but need a photo showing how the factory cut the floor before the tunnel (hump) tacks on. I know about being careful with the crossmember, and that it isnt cut to full size of hump. I see lots of pics of topside with hump installed, but nothing showing floor hole, please help. Much appreciated.
Put the 4 speed jump on the floor. Trace it. Now from that line come in 3/4” and that is you cut line. Do shallow cuts near the tb cross member. Now check fit, happy? Weld in it in! Done, enjoy a beer for a job well done.
Agreed^^^ The hump will only sit in nice in one spot. I've seen a few factory holes cut pretty sloppy, so nothing you do will be any worse then the way they did it.
Here is my 68 coronet.
CF54F67D-E951-4DF4-A639-89642D57E32A.jpeg 10F51819-CC08-43DC-9800-2B3CF5EF8CBC.jpeg 20733B14-B239-4E9F-A479-D8E5075FB001.png E0633D38-3CC9-4640-BCBC-9F6BB69CC844.jpeg
In the first pic, you can see the outline and the cut line that 5.7 was talking about
Also, I used JB weld epoxy to attach the AMD shifter hump. It’s not structural, so instead of welding it in, I epoxied it. The thought was, if I (or a future owner) wanted to convert it back to a column auto, they could remove it and weld in the floor part I cut out.
