Dibbons
- 5:39 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Some of you have been following the front end rebuild of my 1972 Plymouth Satellite Sebring Plus in Mexico using PST parts and torsion bars. The problems previously mentioned:
a) placed lift pads under body pinch welds instead of sub-frames (I was there to save the day)
b) installed upper control arms wrong (driver's side and passenger side swapped) Alignment guy in same shop figured it out and put them back the correct right way.
c) no cotter pins in the ends of strut rods (I noticed that)
d) passenger side tire/wheel installed with the valve stem on the inside (no way to inflate tire, it is also throwing rim offset to the wrong side) Found that out after a brief test drive and I arrived home.
Now the story continues, there are quite a few observations so far, I will explain, post foto(s) and then post, repeat:
#1) The tire valve on the passenger side tire/rim that was installed backwards was ground down to a 45 degree angle after rubbing on something (perhaps the disc brake rotor?) See foto one:
#2) The rotor on the passenger side only spins/turns with an extreme effort by hand (no foto). I see they used the new grease seals and grease cups I provided when I asked for the wheel bearings to be re-packed.
