MSD ready to run work with ramcharger ductwork?
hunt2elk
9:35 AM
WI
https://www.summitracing.com/parts/msd-8386/make/dodge
Have any of you guys used this distributor on a Super Bee or Road Runner that has the fresh air ductwork and oval filter? It is listed as being more than an inch taller than a stock unit. Just dont want to an issue with it hitting the base plate or seal.
I'll go look.. I don't think the cleaner comes out that far..
Height probably not an issue.. the diameter would be the question as I picked up an MSD at an auction and they're huge.
If I get what you’re asking correctly - I have that MSD distributor in my GTX. I also have a six pack set up on it thus the correct air cleaner for same. That would be the oval set up. I don’t have any clearance problems. Everything works well and clears well.
Exactly what I wanted to know, thanks. Do you like the MSD, or would you go another route if doing it again?
Straight on shot and underneath..
