Charger unibody twist while jacking
Maxrat
12:59 PM
Virginia
The 66 Charger is in the body shop -- the body man had it jacked up on the front passenger side to work the front fender and I noticed the passenger door didn't shut like it normally does. Do these unibodies twist a lot if jacked up on one side?
Yes Unibodies will do that. Especially with old cars. Subframe ties will minimize that.
No frame or body rot in it? Steel is flexible though and they to twist but it's not 'a lot'.....
How high was it jacked up on that corner? Never have liked jacking up just one corner unless I had too like changing a tire on the side of the road. I remember my dad's 56 Belvedere being jacked up on one corner and you couldn't open the doors at all but that was a body on frame design and those are more flexible.
The only body rot it had was around the bottom of the back window and a small area under the drivers rocker panel trim. Both areas were cut out and replaced with metal.
Tire was about a foot off the ground.
yes they will twist some
I don't think its anything to worry about
You have a 53 year old body and most likely 53 year old door hinges. It adds up
When I had my interior out I noticed a small wave in the driver's side inner metal panels along the floor
I attribute it to years of twist and a few hard launches that I can neither confirm nor deny
I put frame connectors on mine
Also double check your floor pan just under where the gas pedal would go
A huge number of our cars are soft there
It may look good but push on it and make sure its not soft
Bird on the 2 post hoist.. top of the door is 30% wider than the bottom. My Bee, post car, didn't do that! Also why I CRINGE every time I see someone doing metal work (replacing frame rails and pans) without a car on a jig frame!
