SOLD Late 1965 727 Pushbutton Transmission
-Ed
7:08 PM
Abilene, TX
I have a Big-Block 727 Pushbutton Trans out of my 64, it is a late 65 slip yoke. I Have the cables and button box too, the cover plate is garbage and it’s missing the “neutral” button, but everything else is fine. I’m going floor shift on a later model trans and just don’t really need it. Probably needs built, the car sat for a long time. May do some horse trading if you have a floor shifter setup. Not really sure what it’s worth, but I won’t turn down any reasonable offers. Located in Abilene, TX 79606
B2591E15-FDA6-4B31-B721-8D7D46138C76.jpeg BE5A6FD3-B934-4729-B2BE-E4470D79B721.jpeg 8D51942F-9C60-4D93-87C5-B702BA9369C8.jpeg EE14C519-CAB6-46F5-A640-260AF6801D04.jpeg DA06D23F-2A36-46F6-A932-68FDE69BD888.jpeg
I assume late '64?? That sure looks like a slip yoke, meaning '65 cable shift. HTH, Lefty71
Lefty, it is quite possible you are correct. I assumed it was since it came out of the 64... If enough people concur I will defer to the experts and edit the listing.
Is this transmission still available? Your inbox is full.
if its a 65 cable shift tranny , its 65 only . valve bodies are different from 64 down to the 65 type . even the cables are different . but , that case is a good one , just needs a 64 vb and , 71-76 front pump and input . it has the last year of rear pumps . and two pumps are better then one . using the later input package allows you to get better converters as well as a larger input shaft . just finished one like that for my p/u .
