steve from staten island
- 3:10 PM
- Sep 24, 2012
- staten island,ny
On the firewall harness connection block. The middle connections. There is a blue wire with ring terminal that goes to starter relay. It says "fusible link". The insulation on it melted. I believe it was still connected as I checked continuity and it was ok. The male spade connector is all disclosed from heat......Also in that block is a black wire that runs to the alternator, that connection looked like it got hot also.
The amp meter works but is showing a discharge condition. A voltmeter check at the battery confirmed the battery is not charging.
The wiring is brand new, the amp meter was restored, the circuit breaker for amp meter is new. Everything is new. Any ideas will be appreciated greatly.
