funknut
I've never done any work with seam sealer before so looking for some tips and info on which way to go.
I will be replacing the full front floor pan and want to seal up interior and exterior seams as best I can. I am not super concerned about the OEM look, and I'm sure it's going to look a bit sloppy as it's my first go at this. What I'm really after is first, the best way to keep moisture out, and second, if possible a slightly idiot proof method.
I plan to epoxy prime everything before applying sealer.
First question, for exterior seams I've read of people using fiberglass reinforced body filler instead of seam sealer. I'm not sure if that's because they are going for a smooth look or if it holds up better than seam sealer. Would a modern (3M, Evercoat, Eastwood, SPI, etc.) seam sealer do well on exterior seams? Is there a significant advantage to using a fiberglass filler instead?
There seem to be lots of choices with 2K, 1K and brushable seam sealers vs. the cartridge type. The 2K stuff seems to be about double the cost and I'm not sure if there's any real advantage except that it cures faster?
Lastly, any ballpark of how much of this stuff I will need to do the entire interior cabin? Enough to seal seams, not glob it on the way the factory did. ;)
Anything else I should consider?
Thanks!
Thanks!
