- 8:32 PM
- Mar 28, 2014
- South Louisiana
I have the gauge that shows both O2 sensor readings in real time as A/F ratio or Lambda. Since I have the Edelbrock/Chrysler aluminum 6 bbl intake, which side of the intake feeds which side of the engine? Does the intake cross over or do the carburetors mainly feed the same side of the engine the venturi is on?
Or is it pretty much a mix? Any difference in that equation for the center carb vs the outboard carbs?
