Rob Vaughn
- 10:57 AM
- Apr 11, 2016
Who's got the best idea on the kickdown linkage and throttle cable extension for the trickflow head and intake?
Thanks I seen that .
Didn't know he had the throttle bracket kitsHave you looked at the stuff AR Engineering sells?
http://arengineering.com/home-page/throttle-bracket-kits/
You might check with Andy, he's built engines with Trickflow parts so he'll know what parts he sells will work best.... And his stuff is nice...
Yes but with a lokar cable but not with a KickdownThanks I seen that .
Have you used it?
Andy I got your AR005 and AR 119 from hughes , Mancini said AR didn't make anything, which I knew wasn't true,The Trick Flow intake is tall so you'll need a tall throttle bracket and you'll have to convert over to a cable type kickdown. You'll also need a tall throttle return setup. Hughes Engines or Mancini Racing will have everything you need.
