67belv1
It’s not the brakes. Had the drums off in the video and definitely coming from center. Was turning axle by hand. Wasn’t even ridding in it when the noise started. Oh well maybe put some 4.10s in if chunk is coming out
4.10's hope your not planning to drive more than 20 miles in any direction or on the highway. MO, removed 4.10's this past winter. Unless your trans has OD.It’s not the brakes. Had the drums off in the video and definitely coming from center. Was turning axle by hand. Wasn’t even ridding in it when the noise started. Oh well maybe put some 4.10s in if chunk is coming out
No OD. I am leaning towards 4.10 but still haven’t 100% ruled out 3.91 but the 3.55 just don’t pull enough and top out in the range of being scary4.10's hope your not planning to drive more than 20 miles in any direction or on the highway. MO, removed 4.10's this past winter. Unless your trans has OD.
3.73's. 4.10s x 26" tire 3500 rpm on the highway getting passed by everything.No OD. I am leaning towards 4.10 but still haven’t 100% ruled out 3.91 but the 3.55 just don’t pull enough and top out in the range of being scary
I’m running 29” tires and a set of 26”3.73's. 4.10s x 26" tire 3500 rpm on the highway getting passed by everything.
